Late cub engine into an early cub
Posted by steve midcoast on January 21, 2009 at 17:24:32 from (69.39.100.20):
Putting a later cub low boy engine into my father in laws 48 cub..Noticed a difference where the hydraulic lines go into the front of the block...Coming off the block on the early engine there is an adapter that the two lines bolt into. The adapter is held on with 4 bolts roughly at positions 11 o clock, 1 o clock , and 5 and 7 o clock. The block is threaded in these 4 positions to accept these bolts. The newer cub engine has holes only at the 11 and 5 o clock positions.(this engine did not come with the adapter, so we need to mount the old adapter to the new block) Has anyone done this conversion and just used the 2 bolts to hold on what originally was held on with 4? Or do we need to drill and tap 2 additional holes to mount the adapter that the two lines bolt to? Any info appreciated.thanks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
