Re: IH 434 hydraulic pump??
Posted by IH fan on January 22, 2009 at 03:43:13 from (70.242.82.165):
In Reply to: IH 434 hydraulic pump?? posted by Bill Lavoie on January 21, 2009 at 16:11:46:
Used to test hydraulic systems in a "cold room" environment where I worked (Engineering Experimental)and hydraulic fluid can become pretty thick even at -5 and if the weather has been colder, all that iron may still be colder than -5. Sometimes the engine heat had to warm things up before the fluid would move. I suspect you have run it long enough for that, but for others having problems, it can get pretty bad if the fluid is old with condensation, or the viscosity changes over time.
