Re: Whe is a Tractor Tire Worn Out?
Posted by Janicholson on January 22, 2009 at 08:57:09 from (199.17.6.128):
In Reply to: Whe is a Tractor Tire Worn Out? posted by Jim Allen on January 22, 2009 at 06:45:06:
Tractor tires that slip wast a bit of energy. Thactor tires that slip more than about 10 % of ground speed waste too much. Thactor tire systems and weight that are built to be so heavy and tractive that they do not slip will usually break transmission and drive train components if used in very low gears. Tires that do not slip also --Can--- promote the lugging of engines.
The best is a small amount of slippage 2 to 5% with a confident and aware driver. Weight (beet juice and wheel weights. can keep 1/2 worn tires in action without grief. It is usually a judgement call. I hope this helps. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
