Re: farmall 460 hyd
Posted by kevin in oklahoma on January 22, 2009 at 16:31:40 from (166.128.8.250):
In Reply to: farmall 460 hyd posted by Lee Everetts on January 22, 2009 at 16:13:08:
Lee,
Sounds like a restriction in one of your hoses, whereas your fluid needs to circulate a few minutes to warm and thin out. Also if the weather where you are is to terribly cold may have a little ice building up in your lines when not in use.If hyd pump is run off distributor and engine takes a few minutes to level out that could be your problem.
Just my thoughts as i have seen this several times.
Kevin
