The tractor is strictly used for tillage using mounted equipment for the hardest of the work (9 shank chisel). I don't have wheel weights or liquid ballast. I plan of getting a coupla hundred pound of iron for each wheel for the versatility. I mostly need that weight pulling my 15' cultimulcher with the chisels in deep.
I just found out what the original tread depth was for my tires new, so tomorrow I'll be comparing the current measurement against the new figure.
My manual says I have W15L, 15 inch wide rims but I have not verified that. The tire manual says 15 or 16 inch rims for 18.4-34s. Rim width versus tire section width I understand very well, so I won't be putting 18.4s on it unless my rims fit into the tire's approved rim width range for the tire. I believe I saw markings on the rim but I also have a big set of calipers that might work.
Randy Hall: I have heard about that article but haven't been able to find it. I did find a test that compared R-1 tread against R-2 (and R-1W) and it said that the R-1s are the best in dry to moderately dry conditions. The main difference between the two tires tested was the tread depth, with the R-2s being considerable deep tread tires.
I definitely won't be upgrading to 38s. Everybody wants 'em so they would cost. Ditto for used 38 inch tires. 34s always seem cheaper and I doubt the performance difference compares favorably with the price difference. I ran across some 16 inch wide 34 inch rims at an auction last year, and they went for next to nothing, but I couldn't find out what they fit. I had only minutes to make a WAG, so backed out (got enough scrap iron around here as it is).
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
