Re: Farmall Hydrauic Problems
Posted by Janicholson on January 22, 2009 at 16:38:09 from (68.112.156.69):
In Reply to: Farmall Hydrauic Problems posted by Scott Schotz on January 21, 2009 at 08:51:24:
Two options the easiest is to put a hose on the vent ports and put the hose end into a bucket run the loader up and continue until all the oil is out of the top half of the cylinder. (one side at a time, with the top of the cylinder off of the loader, or both at once with two hoses. and two buckets.) Then (making sure the resivoir is full) try it. Cylinders can and do bypass oil as they sit and you could be looking at a non issue. We ran an H with 2.5"X40" rams W/O extra reservoir.
If you choose to go with the upper cylinder as reservoirs, plumb the top cylinders into the bottom of the reservoir with a pair of "T"s into the drain plug hole. It is neater, and prevents some of the mess. It may be necessary to use a cap instead of the vented cap to keep oil in. No issue with the top of the cylinders putting back what the bottoms use up. JimN
