Re: Checking Tire Pressure
Posted by Owen Aaland on January 22, 2009 at 16:41:47 from (65.161.86.33):
In Reply to: Checking Tire Pressure posted by waygull on January 22, 2009 at 16:12:25:
If you check the air pressure with the stem down the pressure reading will include both the amount of air pressure plus the pressure exerted by the weight of the fluid. You will get a different reading at six o'clock compared to twelve o'clock. This is why a tire with fluid runs with a lower pressure than one without fluid.
To determine what is right for your tractor, park on a hard surface with a bar at six o'clock. The outer end of the bar should be about 1/4 inch off the surface.
