Posted by bc on January 22, 2009 at 18:11:03 from (69.149.215.139):
In Reply to: farmall 460 hyd posted by Lee Everetts on January 22, 2009 at 16:13:08:
Here is what I posted on the 656 thread above which may or may not help. Don't know if it is a governor issue or not:
My 2606 will lug down and die if I don't wait until the engine and the fluid has warmed up or rev it way up. That's usually when I try to pickup the hoe off the ground which takes a lot of hyd. volume. Kinda have to keep it on partial choke till it is warm then it is ok. Now that I think about it, the stall point is when the cylinder has hit the end and it begins to bypass.
Don't know if it is the governor but it works when warmed up. I guess also once I have the loader and hoe off the ground, I can't drive in higher gear until completely warm without it dying. Maybe there is a governor issue when cold?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
