Re: 1941 Farmall H
Posted by Janicholson on January 22, 2009 at 21:33:07 from (68.112.156.69):
In Reply to: Re: 1941 Farmall H posted by IH Country Boy on January 22, 2009 at 18:58:43:
The lift all is the hydraulic system. It is located in the belly of the tractor. A manual (from here, or bindre Books) is really needed. The pump would be located just befor that plate. There are controls and output fittings on the sides. It may not have them, if not it will be one of the three other things leaking. JimN
