Re: upgrade to duals
Posted by mkirsch on January 23, 2009 at 05:19:50 from (64.80.108.55):
In Reply to: upgrade to duals posted by 697447 on January 22, 2009 at 16:51:08:
Axle mount duals are definitely stronger.
One downside on the older Farmalls is the machinations you may need to go through installing and uninstalling due to axle length.
If the tractor has standard axles, the only way two sets of cast centers will fit is if one is dished in and all the way in on the axle. You're golden if you already have your centers installed with the dish facing in; just slide them in. With the dishes facing out, you've got at least twice as much work ahead of you every time you install or remove the duals, most of it heavy and dangerous, especially if you have loaded tires and/or wheel weights.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
