Good Mornin Tom, If you have done another carb before it will be pretty easy for you. The zenith is a pretty easy carb to go through. The kit I got when i did mine on my Super A had good instructions and illustrations.
You are probablly right about the stuck float giving you a leaking problem, very possible ! Get the kit pull the carb apart, clean your parts well in carb cleaner. Make sure all your internal holes are cleaned well and blow out with compressed air.
Make sure you follow the directions on setting the height on the float and I think you will be fine !
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
