Re: Farmall C fuel Tank
Posted by ScottyHOMEy on January 23, 2009 at 09:00:37 from (70.105.253.36):
In Reply to: Farmall C fuel Tank posted by RichV on January 23, 2009 at 08:54:37:
It's a baffle. If you look close and there isn't to much paint on it, you can see the spot welds running crosswise on the top of the tank, behind the filler neck and about a third of the way forward overall, that hold it in place.
Where it's welded to the top, I shouldn't think it would have too much effect on your ability to seal the bottom and sides of the tank, but it may take a little extra by way of physical contortions and sloshing of the sealant to make sure you get things treated sufficiently in the top half toward the rear.
