Return to Oil pan gasket removal
Posted by Blackland Dan on January 23, 2009 at 17:45:00 from (206.248.34.106):
Hey guys. In post #698248 I asked about the best way to remove the oil pan gasket from the crankcase. I got a lot of great ideas and I tried them all, except the air chisel.(I didn't have one)I tried Berryman's spray on gasket removal and that didn't work. So, I got the bright idea to try Easy Off oven cleaner. It worked great... I sprayed it on, waited for a few hours and started scraping with the chisel and it came right off. Try it!!! Thanks for all your help. Dan
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
