Re: mccormik deering 10-20
Posted by spiffy1 on January 23, 2009 at 18:47:58 from (70.41.137.72):
In Reply to: mccormik deering 10-20 posted by 697447 on January 23, 2009 at 13:25:14:
Large chance it has an updated manifold; does your exhaust go up through the hood? Either way, easy enough carbs to work on.
The nice thing if you decide to pull the head; you should have no trouble getting the pistons loose:
ATF; then some diesel on top & lit on fire [I'd never used the fire trick until a 22-36 I have apart right now; sure seems to help!] right before a solid chunk of post and a large hammer -if you can get 2&3 or 1&4 to move up first with the rod caps off all of them, the other two should be quite cooperative for the hammer.
The bad thing, price creep! :
I have the head off, hmmm, maybe I'll have the valves ground.
Valves shot? (likely a couple with issues if it's been getting water in there),
Better put those in.
Guides are shot?
Well since it's apart, better put them in.
EEK; I have $500 [+/- about $300] in the head! No point in blowing all the compression down the bore if the head's perfect.
.030 worn sleeves, and it's pitted too? [minus a nasty combination though, you will hear plenty of success stories with just rings in these]
Errr, just put $500 in the head, better do the $500 for sleeves along with $100 rings. Don't forget a couple hundred for gaskets!
How do the rod bearings look?
What about those mains? Those ball bearings can ring up...$100s Each! Better add some more gaskets to get to the crankshaft.
What about that clutch?
and on
and on :shock: :lol:
That noted; I got several running for no more cost than an oil change and a few gallons in the gas tank, but just warning how easy it is to add one cost on top of another. :P
This post was edited by spiffy1 at 18:53:43 01/23/09.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
