Posted by tractorsam on January 24, 2009 at 17:12:01 from (142.177.27.222):
In Reply to: SMD-WD9 posted by henryv11 on January 24, 2009 at 17:01:59:
On the letter series diesels there were two levers used in the changeover. I believe the number series only used one lever.
On a SMD one lever controls the injection pump (as you don't want diesel being injected when it's running on gas) and also acts like a throttle on diesel. The other lever opens the starting valves (a third valve in each cylinder) and operates a butterfly in the inlet manifold to direct air around or through the carburetor as required. The shaft that the butterfly is on also has an electrical switch attached to engage/disengage the mag/distributor. The starting valve opens to an additional combustion chamber to lower the compression ratio sufficiently for it to run on gasoline. Hope this helps, Sam
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
