Re: adding power beyond on a 1086
Posted by Steven f/AZ on January 24, 2009 at 17:33:41 from (24.121.133.155):
In Reply to: adding power beyond on a 1086 posted by Doc 2 on January 23, 2009 at 14:56:52:
Loggy said: (quoted from post at 13:37:35 01/24/09) It looks like from the picture that I could still use the PTO and the pump at the same time. Is that right?
The PTO shaft sticking out the pump is something we had a machine shop make for us. It wedges inside the splines of the pump so we could run the feedwagon without removing the pump. All the power is transmitted through the pump shaft, so having something that required a lot of power might not be a good idea, but we ran grain augers, grinder mixer, and feedwagon that way.
There are also long extension shafts that will go all the way through the pump and have enough sticking out to connect to, those would handle more power in my opinion. The pump would be back a bit farther, though.
