Re: throttle problem
Posted by Gene Bender on January 24, 2009 at 23:07:21 from (67.55.226.75):
In Reply to: throttle problem posted by Jimmy in TN on January 24, 2009 at 20:51:00:
Could be the spring in the govenor or maybe the linkage needs to be adjusted to factory setting.
