Re: M carb questions
Posted by wayne in MN on January 25, 2009 at 08:22:41 from (71.146.10.42):
In Reply to: M carb questions posted by Charles E. McNelly III on January 24, 2009 at 20:27:17:
Not to worry; just make sure the carb is clean, adjust the idle air acrew, adjust the main fuel screw, and idle rpm's. You do not need a different carburetor.
My oldest son has a 1943 M with distillate carb and runs just fine with gasoline (10% ethanol).
Have fun with the M; it is a great machine.
