Re: 140 overhaul 1958 model
Posted by the tractor vet on January 25, 2009 at 10:25:33 from (99.167.210.144):
In Reply to: Re: 140 overhaul 1958 model posted by Gene Bender on January 25, 2009 at 08:52:32:
Now i know i am not the leading guru on the A-140 But i also stated to take the Cam in also and this way they can check the bore in the block to the surface on the cam bearing and see what it is then if there is tomuch then either build up and regrind the cam or bore the block and install bearings to get it back in specs so that it will make good oil pressure. Where there is a will there is a way to make it work .
