Re: engine replacment
Posted by Janicholson on January 25, 2009 at 13:59:08 from (66.173.50.96):
In Reply to: engine replacment posted by sven on January 25, 2009 at 13:49:23:
No reason at all. Make sure all engine mounts/front cover and assorted fittings are switched as necessary. Depending on the powerunit output system, it might need a pilot bearing bore made in the crankshaft FW end. The pump governor might also be set higher or lower in RPM. Some governors are also not designed for variable speed use, so checking that is very important. JimN
