Posted by Janicholson on January 25, 2009 at 14:05:21 from (66.173.50.96):
In Reply to: M Farmall ????? posted by bigramjack on January 25, 2009 at 13:42:06:
The arms are for a radiator shutter system (probably gone) that raised engine temp for use with distillate fuel. The running issue could be as simple as setting and cleaning the points. Do not replace components one after another until it runs. The analysis process is best done by thinking about the symptoms. The distributor cap could have condensation or cracks. Try the point adjustment first. If it is a mag, the points are behind the geared rotor mechanism. Note carefully where the rotor is pointing before removing the rotor!. Gap is .013" mag, .020" distributor. JimN
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity!
... [Read Article]
