Re: A vs B
Posted by Jim Becker on January 26, 2009 at 08:21:53 from (71.252.139.51):
In Reply to: A vs B posted by sgtbull on January 24, 2009 at 12:01:15:
The way the A and B were designed, it is possible to bolt all sorts of combinations of parts together, almost like tinker toys.
To move the left housing back out to the original location on a B, you will need the axle housing and the shaft. The housing can come from either side but the shaft needs to be a left. You will also need the correct drawbar.
IH never sold a B with a wide front axle. They evaluated it at least twice but decided it was cost prohibitive. I have seen them with A front ends (which puts the axle pivot off center). I have also seen a C axle on at least one. That requires modification of the front housing to add an adapter plate for the C axle.
