Re: Questions about distributor live pump for an M?
Posted by D Slater on January 26, 2009 at 11:00:06 from (71.164.47.136):
In Reply to: Questions about distributor live pump for an M? posted by unioncreek on January 26, 2009 at 09:53:45:
That pump # is for a diesel. Type pump used by IH gas engines is a fairly easy bolt up if the M engine is serial # 228083 or higher. There's more than one way to make it work if lower, but takes more work if serial is lower and nothing has already been changed. A port block can be got aftermarket, made, or from another IH tractor.
You should use a pressure relief valve in system and if you don't need the extra pressure set it at 1000 PSI or a little lower and whatever cam gear you have in engine may last.
Disclaimer, Some information from IH and other sources can have conflicting answers. Also all parts of units in question are subject to changes by dealer, others and end user. Above answer is made in good faith but with no guarantee to be correct.
