Re: Turning a flywheel
Posted by Gene Bender on January 26, 2009 at 12:50:16 from (67.55.226.75):
In Reply to: Turning a flywheel posted by Mark W. on January 26, 2009 at 11:32:07:
Find a shop that will surface grind them. It is a special machine and will grind just enough to remove the glaze. You only need to remove a couple thous. Dont remove any more than that or yoa can run into problems with the pressure plate.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
