Re: 560 Fast Hitch Drawbar
Posted by AOOC on January 26, 2009 at 17:23:52 from (71.163.162.253):
In Reply to: Re: 560 Fast Hitch Drawbar posted by LouNY on January 25, 2009 at 17:33:09:
Lou,
The swinging drawbar was a great addition to those early tractors which had a fast hitch, for example the 1954 Super C, even thou you had the u shape drawbar this tractor came with a swinging drawbar (which was great when you pulled a disk) that hooked under the belly of the tractor. Whenever we pulled something heavy, my grandfather would forbid us from pulling from the the drawbar itself, saying we would break something. Pulling off the swinging drawbar you actually would pull from the belly of the tractor...it would help to keep the front end on the ground as well, especially on those lighter weighted tractors. I have seen these swinging drawbars on Super C's and other models including the 806's.
The attachment triangle piece you mentioned which bolts on to the drawbar with two/three bolts works as an alternative to the swing drawbar because you can attach certain equipment eight or so inches further behind the tractor. Without this attachment or the swing drawbar many implements are attached to close to the tractor and interferes with turning(rear wheels hitting the implement your towing)
Anyway, thanks for your response on this topic. I learn something everyday.
(I have a fast hitch manual in front of me, with traction control) and it does not even mention a swinging drawbar)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
