Simple diagnosis: Plug up the exhaust while running. If it runs and the exhaust coming out of the breather increases proportionatly. the answer is a exhaust port broken into the crank case. Frozen water damage. Put weak rag sealed air pressure into the crancase with the valve train taken loose so the exhaust valves are all closed. If the air pressure is heard in the exhaust pipe/muffler, the head is cracked/ broken as described above. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
