Charles, it kinda looks like you might have used up about all your adjustment. Probably want to check your pad thicknesses when you get it off. Lay a straight edge across your brake housing and use feeler guages to see how much gap you have as a reference (at some point you may have to machine some off along with replacing the pads). I'm not sure the actuator disks actually wear that much. More wear on the surface on the inside of the housing and on the rear end housing. Lay a straight edge on that surface to check it for wear.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
