Re: Snowblower on 666
Posted by Michael Soldan on January 27, 2009 at 06:45:34 from (24.235.41.171):
In Reply to: Snowblower on 666 posted by JMS II on January 27, 2009 at 05:39:21:
Look over the drive chain and cogs carefully for signs of excessive wear. If the cog teeth are worn thin near the ends and have a slight bend to them they are done and the chain that caused this is done too. Chain should not play side to side, if it does its badly worn. (All this can be replaced if the price of the blower is right..$200 t0 $300 in parts. Check the gear box for leaks and any play when you turn it back and forth by hand. Your 666 should handle all but the deepest drifts that are higher than the blower..in which case you raise the blower a couple of feet and make a pass then drop the blower and clean up.Your lowest gear and range in reverse will let you blow deep and heavy snow without any problem.
