Re: 560 f-11 loader
Posted by Allan In NE on January 27, 2009 at 07:54:00 from (148.78.243.26):
In Reply to: 560 f-11 loader posted by RUSS WERNING on January 27, 2009 at 07:46:03:
HI Russ,
I'd sure use the PTO pump, especially so since you already have a live PTO. Just can't beat the quick-operation, 19gpm output of those pumps.
Yes, you can mount it directly to the axles on a 560. There's plenty of room up front and no need for the extensions.
Allan
