Re: I Got Told 12 Volt and Starter Don't Mix - Warning
Posted by mkirsch on January 27, 2009 at 12:26:38 from (64.80.108.55):
In Reply to: I Got Told 12 Volt and Starter Don't Mix - Warning posted by Hugh MacKay on January 27, 2009 at 12:02:44:
...not because of 12 Volt, but because the clutch type is THAT MUCH BETTER.
Usually what kills starters on 12V is the crank and crank and crank and crank and crank and crank and crank and crank and crank because the engine isn't tuned up or the operator doesn't know how to start the tractor. If your tractor fires right up the starter will last a long time on 12V.
