Carburetor Repair Kit No Good
Posted by Tom in Iowa City on January 27, 2009 at 16:15:21 from (173.19.92.27):
1941 Farmall A.
Serial No. F.A.A.77497.
Zenith carburetor 161 x 7, 9752.
I am rebuilding this carb and ordered a kit from Yesterday's Tractors. The delivery was very prompt.
However, the kit is poor.
The gaskets and throttle shaft are fine, but,
1. The choke shaft splines that interface with the lever that connects to the choke linkage are a "coarse" instead of a "fine" spacing, so the lever will not fit.
2. The fuel valve seat is oversized by 14 thousandths so it will not fit.
3. There was no brass throttle shaft packing retainer included in the kit.
This product is a Tisco kit, labeled C509V and IS specified, on the packaging, for Zenith carbs of the number 9752, which mine is.
What gives?
Has anyone had a similar experience and where do I get the proper kit?
Thanks,
Tom
