Re: I Got Told 12 Volt and Starter Don't Mix - Warning
Posted by IH fan on January 27, 2009 at 16:16:34 from (69.155.40.222):
In Reply to: I Got Told 12 Volt and Starter Don't Mix - Warning posted by Oldtractorfun on January 27, 2009 at 12:02:44:
My 240U (123 engine) was switched to 12V before I bought it and I'm certain it's still the 6V starter. Maybe I need to be careful with cranking it too long... glad I read this post. The carb on mine does not have a choke cable attached, but when it's warm, it starts right off with the throttle just barely cracked open... when cold it needs the throttle completely closed.
