Re: I Got Told 12 Volt and Starter Don't Mix - Warning
Posted by NDS on January 27, 2009 at 17:39:14 from (205.188.116.73):
In Reply to: I Got Told 12 Volt and Starter Don't Mix - Warning posted by Oldtractorfun on January 27, 2009 at 12:02:44:
Six volt tractors are fine if you have right cables keep all connections clean and tight with fully charged battery. As for as starters not working on 12 volts we starting switching tractors to 12 volts in fiftys and have had at least a couple of 12 volt letter series around for over fifty years and have always gotten pretty good service out of starters. Back in fiftys our tractors would run at least 1000 hours/year.
