I use a 6 volt starter (no solenoid) on an H with a 12 volt battery. It works fine. C113's, 123's simply do not need 12 volts, I have 2 of those. Just maintain the 6 volt system. Also, it has been stated many times on this forum that 12 volts will not hurt a starter -- I have read about the different clutches, but have not had that problem either.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
