Re: F-20 / Farmall Regular
Posted by Old-F20 on January 27, 2009 at 18:30:15 from (71.7.98.117):
In Reply to: F-20 / Farmall Regular posted by Andy Motteberg on January 27, 2009 at 17:07:06:
cmykittin69 said: (quoted from post at 18:07:06 01/27/09) I have a Farmall Regular and need to know part numbers or sizes for the front wheels? Also the wheel nut size. This tractor is 75-80 miles away and I have a set of f-20 wheels for it but no bearings and wheel nuts. Thanks for any help!
everything on a late regular (late 26 & up) and F-20 interchange on the front wheels. if you only need i tot roll, only get enough stuff for one wheel
