Re: 6-12 volt change for H International
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 05, 2000 at 05:56:08 from (12.75.221.121):
In Reply to: 6-12 volt change for H International posted by Rodney on April 04, 2000 at 17:56:44:
If you are speaking about a Farmall H, you need the following.
12 volt battery of course.
You can take your 6 volt generator to a good electric shop and they can convert it to 12 volt and add a Delco 12 volt voltage regulator as either a stand alone on the rear gas tank bracket or mounted on the generator depending on your settup.
Resistor in the coil line to drop 12 volts down to around 6 for the coil, points and condensor.
12 volt light bulbs if you have lights.
Budget $200-250 for the conversion as described.
Post A Followup
: Re: Re: 6-12 volt change for H International
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
