I'm not sure there is a minimum disk thickness. Go until you run out of adjustment. If they are down to flat with the grooves and you still have adjustment, I suppose you could cut the original grooves a little deeper. There is still pad where the grooves are.
New pads are a hair over 1/2" thick. Maybe close to about 9/16".
If you got adjustment and pad left, I'd say your lucky. Those actuators only spread so much. At some point new pads won't work and you have to machine off some of the housing surface.
Part of the reason it may have broke (maybe) is that you are out of adjustment. The two actuator rods from the clevis to the disks pull tight against the housing as you adjust the ball up too much. Then the actuator disk spread has reached its limit. You will see that when you get the housing off. Let us know.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
