Re: I Got Told 12 Volt and Starter Don't Mix - Warning
Posted by charles todd on January 27, 2009 at 20:12:18 from (205.242.95.132):
In Reply to: I Got Told 12 Volt and Starter Don't Mix - Warning posted by Oldtractorfun on January 27, 2009 at 12:02:44:
I am 28 and my fathers Ford 841 has had a 6V starter on a 12V battery as long as I can remember. It probably takes 5-6 seconds to start even in Louisiana's bitter 40 degree winters 8) Most likely the battery cable was corroded or they had a hard time finding 6V batterys... I am sure even it being a 44 hp gasser it would spin on 6V easily. Old 6 and 8 cylinder vehicles from the past (lower compression) cranked on 6V, much more engine than any 6V tractor. I do not know where I am going with this... I am tired. Goodnight.
Charles
