Posted by D Slater on January 28, 2009 at 05:06:36 from (72.65.137.103):
In Reply to: Increasing Horsepower posted by IHRedRules on January 27, 2009 at 19:02:52:
You wanted someone who knows what there talking about. At this point in my life I know just enough to know there's a lot I don't know, so I will just answer the part about heads and a little more. If comparing original 300 and 350 heads that were for same fuel type, there the same. Differences I know in original C169 and C175 engines as they progressed.C-169 used 3-9/16 bore. Early in production C169 had a dipstick added and petcocks in oil pan droped unless distillite or kerosene. C169 changed from a R1 carb. to R2, R2 continued on 350. Camshaft gear was changed from DA to DB. Connecting rods and pistons were changed to use a smaller piston pin. C-175 engines used 3-5/8 bore, by now most C169 have been changed to a C175. The pistons and sleeves will fit right in with correct piston pin size or adapter bushings in rod. Early in 350 production the intake exhaust manifold was changed a little from 300 type on gas tractors. During 350 production the camshaft was changed to use left hand threads and nut to hold cam gear on. Rest of cam stayed the same as 300 and early 350. There was other small changes that don't amount to much between the engines and as production progressed.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
