Re: Super A Hard to start when hot
Posted by Janicholson on January 28, 2009 at 06:16:00 from (199.17.6.128):
In Reply to: Re: Super A Hard to start when hot posted by DUNNDAN on January 28, 2009 at 05:44:24:
If you have a ballast resistor in it now, then the coil should be 12v for use with a ballast resistor. If it has no resistor now a coil designed for 12v no resistor required is best.
If hand cranked it makes no real difference.
Putting a choke cable and control near the front might be a positive addition. Shutting off fuel when it is hot can limit loading of extra fuel into the carb (which can cause hard starting) JimN
