Re: I Got Told 12 Volt and Starter Don't Mix - Warning
Posted by Fixerupper on January 28, 2009 at 06:29:08 from (66.43.238.99):
In Reply to: Re: I Got Told 12 Volt and Starter Don't Mix - Warning posted by Steven f/AZ on January 27, 2009 at 16:37:24:
Right on, Steven! Most 6V tractors start fine when everything is up to snuff, as it should be on any tractor. Right now my 6 volt SC Case is sitting outside hooked to an auger and has started on every sub-zero morning so far.
The tractors in the 40-50 HP range like the M Farmall, Oliver 88 etc. were stretching the limit for 6V when new, but now most of them have oversized pistons, so a 12V conversion is almost a necessity for them. Jim
