Posted by Janicholson on January 28, 2009 at 10:29:02 from (199.17.6.128):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
The clutch disk can be put in wrong. If the flywheel side is not to the flywheel, it will not release. The drive hub rubs on the flywheel mount. This or bad spline wear on the clutch shaft, or a bad pilot bearing will cause the issue. If the disk got bent from pressure during insertion of the engine to trans, the bent hub will also drag on the Drive components. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
