Re: Farmall B clutch
Posted by Red Dave on January 28, 2009 at 10:46:48 from (66.216.141.163):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
The step in the flywheel should be cut when the flywheel is refaced. The dimension is in the repair manual, I don't remember it offhand.
However, if it is not ground, it seems to me that the clutch would slip, not fail to release.
Sounds like maybe a bad pilot bearing, or the pressure plate fingers are not adjusted right. Is the throwout bearing facing worn? That might do it too. I would always replace the pressure plate and throwout bearing with the disk rather than have to go back into it another time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
