Re: Farmall H Distributor
Posted by D Slater on January 28, 2009 at 12:26:31 from (71.164.63.11):
In Reply to: Farmall H Distributor posted by neblinc on January 28, 2009 at 10:10:21:
Randy, don't know which operators manual if any you have. Most after 1949 tells the lubrication, mantinance and how to time distributor. Looks like your doing a top notch job on engine so you probably want to go through distributor and check it out. The T shaped gear usualy wears faster than the one on end of distributor itself, but check both. Check that drive gear and pin are tight on distributor shaft, you may have to remove them if completly taking distributor apart though. Theres a oring seal in housing above gear but if other things check out okay I don't think its critical enough to pull shaft to change. Down below point plate you should check weight guard, weights for worn holes and the pins weight swing on for wear or being loose in distributor shaft, also advance springs. Weight guard is often found mangeled by to long of screw installed in condenser mount. Check advance limit hole for wear. Check point cam for to much play between it and distributor shaft, also that it has the oil wick in it for lubrication. Check main distributor shaft for play and the bushing for T shaped drive gear. Bushing for distributor shaft in housing is poris so the grease when lubing doesn't go dirrect on shaft. Also you can't overgrease that because extra grease will come out hole on opposite side. Lightly lube moving parts of advance unit and if distributor shaft is removed the thrust washer under big end of shaft. On a 50 H if original the distributor drive housing that is between engine and unit has a oil seal in the housing. Drive gear and shaft is removed from housing to replace. I mostly just mentioned the stuff inside and left some stuff out. Good luck
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
