Re: A Suggestion
Posted by mkirsch on January 28, 2009 at 13:54:39 from (64.80.108.55):
In Reply to: A Suggestion posted by Heifer Raiser on January 28, 2009 at 09:45:49:
Searching these forums is often like a mindreading exercise. If you don't use the same set of keywords as the other guy with the same problem, you don't find their post. When was the last time someone described a problem using the same exact wording and technical terms as you? Doesn't happen frequently, and when it does it's two experienced wrenchers talking about how they fixed the problem.
A less experienced person is often reduced to using terms along the lines of "engine spinny thingy," to mean starter, for example.
