pull a spark plug, hook it up to the plug wire, lay it on the motor so it is grounded and crank it over. you should have a good blue spark. if not, pop the cap rotor and dust cover off, hook the end of the spark plug wire into the coil, then with the ignition on, open and close the points. you should get a brite blue spark, if not sand the points lightly with some 320 or 400 grit paper and try again. if not, i'd start looking at the condenser, or possibly a short where the wire goes thru the distributor and connects to the points.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
