Re: H brake disc
Posted by D Slater on January 29, 2009 at 13:20:43 from (71.164.53.101):
In Reply to: Re: H brake disc posted by rustyfarmall on January 29, 2009 at 13:05:24:
Rusty does it show 6 X 3-1/8 for a M. I had that wrote down but didn't write enough info along with it to be sure on a answer.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
