The mounting flange (where you loosen the clamps to set timing) has a code letter stamped into the outer edge. The unit from the C may have originally been on something else. The C distributor is code J, the M distributor is code A.
Code A maximum advance is 40 degrees at 1400 rpm.
Code J maximum advance is 30 degrees at 1400 rpm.
By the way, the Super M used distributor J, so I'm guessing it doesn't matter much which one you use.
By the way, the springs determine how quckly the spark advances but the maximum is determined by the shaft. Both the springs and shaft are different between the A and J distributors.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
