Re: 350 utility restoration questions
Posted by Janicholson on January 29, 2009 at 14:57:17 from (68.112.156.69):
In Reply to: 350 utility restoration questions posted by Dyna on January 29, 2009 at 12:48:54:
The pump seal is bad and easily repaired. Tractorsam is correct. The seal is a few bucks, the speedy sleeve is only needed if the shaft is grooved at the seal lip. Some are "O"rings some are regular seals. The Oring lip must be machined to allow the speedy sleeve into the hole, bit it is not problematic. I would not try to move the pump, there is no better place for it. and still have ut live and powerful. JimN
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
