Re: 350 utility restoration questions
Posted by DYNA on January 29, 2009 at 17:37:24 from (72.228.74.5):
In Reply to: 350 utility restoration questions posted by Dyna on January 29, 2009 at 12:48:54:
Thanks for the advice. Your correct about the distributer on the other side. My thoughts were to move it because I was told this problem happens to them all the time. I could make a different pump drive off the front of the crank with some work. I would like to avoid any extra work if possible. So if the pump is fixed I should be satisfied?? Any other problems with this hydraulic system? I have some knowledge on tractors but none on this models good points or bad points so any info is greatly appreciated.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
